JVC Model No. AV-65WP74
sgatlantis83
PostPosted: Sun Aug 02, 2009 11:20 am    Post subject: JVC Model No. AV-65WP74 Reply with quote
this TV is about 5 years oldc now and red lines started dipping down from the top. it arches down further in the middle then on the ends. i had a T.V. repair guy come out and tell me what was wrong with it. He wrote on the estimate that it needed a total convergence. I am a ground radio tech in the air force with about 7 years experience. i was hoping to get a better idea of how to do this myself but i dont really even know what a convergence problem is any light you can shed on this will be helpful. thanks for the help.
PostPosted: Sun Aug 02, 2009 11:39 am    Post subject: Reply with quote
convergence is the system that aligns the 3 CRT lenses to form a single images. so the picture includes a combination of the 3 colors overlayed. To form a picture, the 3 colors "converge" on one spot.
The TV has electronics to adjust those, typically called convergence amps. These are high power chips, and they sometimes fry. The parts are cheap, but the labor is expensive.
You can do it yourself easily if you are good at de-soldering and soldering.
PostPosted: Sun Aug 02, 2009 11:45 am    Post subject: Reply with quote
you need two of these: STK392-110
and you can order them from Acme-sales.net (see link above on top right)
They're attached to a HUGE heatsink on the circuit board.
