JVC plasma pd-42wv74 no video, but audio is fine
jonwal1
PostPosted: Thu Aug 20, 2009 2:29 am    Post subject: JVC plasma pd-42wv74 no video, but audio is fine Reply with quote
This is an older unit with the seperate media receiver. If the unit is unplugged overnight it will display for about 30 seconds before it turns off. When this happens I get a slow blinking power light. I checked all the fuses and removed the power board to check for cold solder joints. One thing I find odd is i have 123 vac coming in at the main fuse, but when I power it up I only have 120 for a split second then it cuts down to 67vac.
I tried to isolate the problem by hooking up the dvi output of the reciever to a known good monitor when I powered it up today. That showed the same results. I had about a minute of the screen working on a known good monitor followed by a loss of video (signal). The audio worked the whole time.
I also hooked a dvi dvd player up through the display after that and I could not get any video. Every time I did that I got the blinking green light. Strangely if I hooked the 42" display to the receiver I would not get video, however I did not get any blinking light either. I may take the cover off the reciever unit tomorrow and see if any caps look swolen or if I can identify any other irregularitites.
jonwal1
PostPosted: Tue Aug 25, 2009 5:48 pm    Post subject: Reply with quote
The tv will power up fine as long as there is not a dvi cable plugged in. To make sure it was not the receiver I plugged a seperate dvd player through the dvi cable into the tv. The tv had audio, but as soon I plugged the dvi into the panel it shutdown and led8004 came on.
