K02P128.02 Schematic?
AciDDreamZ
PostPosted: Mon May 20, 2013 6:00 am    Post subject: K02P128.02 Schematic? Reply with quote
Hello, i have a samsung television with the K02P128.02 inverter/power supply board. There are no visual defects, so i am wondering if any of you might have a schematic i could get for this board?
AciDDreamZ
PostPosted: Wed May 22, 2013 5:44 am    Post subject: Reply with quote
Symptoms;
At first powering up, it will turn on and off for a few minutes and then give up and stay off. Try and turn on again, it will rinse and repeat. Unit does have sound. I've checked all Electrolitic caps on the power supply.
PostPosted: Wed May 22, 2013 2:18 pm    Post subject: Reply with quote
what model of TV is?
AciDDreamZ
PostPosted: Wed May 22, 2013 4:14 pm    Post subject: Reply with quote
Samsung LN32A330J1N
PostPosted: Wed May 22, 2013 6:22 pm    Post subject: Reply with quote
One of (or more) of these may be close enough?
http://elektrotanya.com/?q=showresult&what=LN32A330&kategoria=&kat2=all
AciDDreamZ
PostPosted: Sat May 25, 2013 8:23 am    Post subject: Reply with quote
Hey, thanks but no...none of those match sadly Sad. This is really turning into quite the challenge for me, i have checked the Ele Caps, diodes, transisters, all cables, reflowed any fillet that looked like it might have become a cold solder joint :-/
