KP61V80 4 blink code and smoke from capacitor
brian110
PostPosted: Sat Dec 26, 2009 10:06 pm    Post subject: KP61V80 4 blink code and smoke from capacitor Reply with quote
i GOT THIS 60" SONY FOR FREE IN HOPE TO REPAIR. The only info I got on it was that it got error code 4. when I
pluged it in I indeed got the code 4 repeating over and over. but then I smelled something and then seen smoke.
upon feather investigation I seen capacitor C521 burned out. I'm not sure if this happened before I got it or not.
but I pluged it in again and did not get smoke this time.
when I first pluged it in I heard the tv turn and and can fill static on my hair. and then the smoke. after that no
tv electric static. but still getting the 4 code. What should I look for or should I replace? I have a multimeter
to test if need be.
Thanks,
Brian
PostPosted: Sun Dec 27, 2009 4:07 am    Post subject: Reply with quote
Where is your head/hair/toupee? Near HV splitter, flyback, CRT anode wire?
How sure are you on capacitor's location number?
Anyway "found on web:"
Q502 horizontal output transistor shorted C517 burned & shorted.
Found C512 (102@2KV) shorted across Collector/Emitter of Q502.
brian110
PostPosted: Sun Dec 27, 2009 9:05 am    Post subject: Reply with quote
click on pic for large view.
I think its the right location
PostPosted: Sun Dec 27, 2009 1:49 pm    Post subject: Reply with quote
Can you post a picture from opposite angle from the metal heat sink. Is transistor on that Q502?
brian110
PostPosted: Sun Dec 27, 2009 2:40 pm    Post subject: Reply with quote
PostPosted: Sun Dec 27, 2009 6:53 pm    Post subject: Reply with quote
Look between heat sink and red/green/blue caps. Wink
brian110
PostPosted: Sun Dec 27, 2009 7:04 pm    Post subject: Reply with quote
Yes c517 cap is there burned out. replacing... along with transister
