_Gabe Guest
Posted: Tue Mar 10, 2009 10:54 am Post subject: LA7836 replacement |
I need a LA7836 in a Panasonic tv , but I have none in stock,
Can I sub with another one ? like LA7837 ? or 35 ?
these I have in stock. |
_Gary Guest
Posted: Tue Mar 10, 2009 10:54 am Post subject: |
NO
7837=7085 nte
7836=7104
7835=1885
-do you have nte's software?
-do you have an old nte/ecg paper catalog?
-with both you can look up your ic and cross check pinouts/specs (there are
also links in the software to nte's data sheets-I find it's just as fast to
look in the paper catalog)
-or you could probably find spec sheets online somewhere if you want to
confirm my opinion |
_Steve Guest
Do you have access to an NTE7085?? It should be a direct cross..
Steve |
_John Guest
Posted: Tue Mar 10, 2009 10:55 am Post subject: |
Good morning. To the best of my knowledge;
LA7830 is unique (7 pin)
LA7831 is unique (10 pin)
LA7833 replaces a LA7832
LA7835 replaces a LA7836
LA7838 replaces a LA7837
BUT not the other way around. The replacement ICs have higher B+ and are
used in larger screen sets.
LA7840 and LA7841 cross to same NTE7153, I'm not sure which is stronger.
LA7845 is unique ?, using + and - supplies.
LA7848 is unique, 7 pin but different pin arrangement.
LA78040 replaces AN5522 and TDA8172
LA78041 is unique
LA78045 is unique, using + and - supplies.
John. |
_Steve Guest
NO
LA7836=7085
LA7835=1855
LA7837=7104
I confirmed this with the NTE software, and the book. |
_Kelton Guest
Posted: Tue Mar 10, 2009 10:56 am Post subject: |
I think there might be a reference zener that sets up the voltage on pin1,
make sure the supply is clean/ replace the diode.
change the capacitors on pin1, along with the other supply caps. (pin 7? &
13).
those panasonics had a bunch of bad .01 or .1uf caps throughout the set too. |
