le40f71bx/xec - works intermittently
johnnyph
PostPosted: Wed Jan 27, 2016 2:03 am    Post subject: le40f71bx/xec - works intermittently Reply with quote
Here is a video https://youtu.be/QX5EVhvtJ_U
Yesterday it worked today it does not. And maybe tomorrow it works again. i took the backoff and it worked better. What can it be
PostPosted: Wed Jan 27, 2016 2:48 am    Post subject: Reply with quote
"So if your air conditioner goes on the fritz, or your washing machine blows up, or your video recorder conks out, before you call the repairman, turn on all the lights, check all the closets and cupboards, look under all the beds, 'cause you never can tell. There just might be a gremlin in your house."
Model number?
What shows that that source is working? You don't show what is being used and that either the same works with a second TV or a second source on a second input works or not.
johnnyph
PostPosted: Wed Jan 27, 2016 4:49 am    Post subject: Reply with quote
Model nr le40f71bx/xec cant find anything on the internet about this model. Its all input and its a ps3 connected. Sometimes its only vertical white lines flickering on the middle of the screen. And then it goes to whats in the video
johnnyph
PostPosted: Wed Jan 27, 2016 5:06 am    Post subject: Reply with quote
Okey learnd something new ps3 is working on 576p and 720p and 1080i. But when is activate settings to run also on 1080p normal full hd. It does what it does in the video hmmm
