LG 50LB6300 - Need LED Backlight Diode pt#
megawatt
PostPosted: Mon Sep 24, 2018 7:15 pm    Post subject: LG 50LB6300 - Need LED Backlight Diode pt# Reply with quote
(Need Tech Help) Backlight LG 50lb6300
I have troubleshooted my LG 50lb6300 for flashing screen .
I have several bad led's on my backlight strips
I want to replace the diodes instead of buying the backlight kits.
I called one online repair shop that were out of stock. He said this tv uses 6v led diodes. I have checked and believe they are the LG 3535 diodes but I see they come in 1w and 2w does anyone know what I should get? if it matters.
The backlight strips are 6916L-1735a 6916L-1736a
Does anyone know if this is 6v and not 3v and what watt ?
Can put me on the right diode to buy
Thanks
PostPosted: Fri Sep 28, 2018 12:01 pm    Post subject: Reply with quote
I don't know the answer to your question.
However, i have previously tried to do what you're attempting to do with a different LCD TV, and I was not successful. The LEDs that I replaced did not have the same color or brightness intensity of the existing ones at the same voltages. They were the same part#. I chalked it up to having burn time on some of the LEDs
