LG 50PZ550-UA - Double, Triple Video images
jkun41
PostPosted: Thu Jan 19, 2017 8:57 pm    Post subject: LG 50PZ550-UA - Double, Triple Video images Reply with quote
Hi all, I was hoping for some input on a TV that recently started acting up.
This may be unrelated, but about a year ago the 1080p hdmi stopped worked (would flicker, flash, make a hazy noise,) but 1080i worked fine.
Last week, I turned my tv on before bed and there was this:
The top left corner has a blue bar that moves a few pixels each way. The picture on the screen goes double, triple, and bounces around. Sometimes it will go solid, but usually just flickers with the double/triple image. If I press input the picture appears to freeze (as well as continue to flicker) as I cannot see my selected highlite moving. I took a video, but unsure where to host it.
Edit: forgot to mention; sound works fine.
TV info:
Model: 50PZ550-UA
LG Plasma 3D TV
Manufactured: July 2011
Hope you can help, thanks.
barrye32
PostPosted: Sat Apr 22, 2017 9:31 pm    Post subject: Reply with quote
Bga on the mainboard is getting loose( cracked solderballs)
The board is bending because off the heat and the coolblock sitting on top off it
Reflow the Bga or better replace the solderballs underneed it
When you done this put something underneed the board so it will not bend anymore
Something like a silicone coolpad or coolblock
Good luck
