LG 55LH40 has Sound but No Picture
kg5ie51
PostPosted: Tue Jul 31, 2012 3:06 pm    Post subject: LG 55LH40 has Sound but No Picture Reply with quote
I have an LG 55LH40 that has died. The unit has sound but no picture. I removed the back and found that 2 of the 14 wires that connect the VIT71881.00 Master 1 and the VIT71881.01 Master 2 inverter boards were blackened and burned. The connectors themselves are also slightly melted.
I assume one or both of these boards must be bad though I have no way to test them. I looked for parts and found that I can buy the Master 1 or Master 2 boards separately, or I can buy a kit that includes the Master 1, Master 2, Slave 1, and Slave 2 boards.
Master boards are about $35 each. The kit of all 4 boards is $180.
My question is whether or not I should chance buying just the masters or should I assume that more than likely the issue took out the slaves too?
Thoughts?
Thanks in advance.
PostPosted: Tue Jul 31, 2012 3:57 pm    Post subject: Reply with quote
kg5ie51 wrote:
The unit has picture but no sound.
Inverter boards would be involved ONLY IF you have this backwards.
kg5ie51
PostPosted: Tue Jul 31, 2012 6:21 pm    Post subject: Reply with quote
Whoops! You are correct. Got it correct in title and backwards in posting. Have sound but no picture.
