huntertownsen
Posted: Tue Jan 24, 2017 8:12 pm Post subject: LG 60ln5600-ub - no sound and vertical lines |
Hi thx for the forum 60ln5600-ub lg led tv, vertical black and white lines, no sound. unusual problem, it does have a few colored lines about a pixel width, every source change shows up differently on the screen.
I believe the main board where the input, for audio video is out , I havent found anything on the web with a similiar problem, some of the sources are black and white lines just in the center 1/3 of the screen , black on the outside, some are all gray and black lines. thee is no sound at all , i have hooked up video and audio inputs the all the hdmi and rca jacks, the only difference i can see are a few small green blue and red lines when there is input. I thought tcon board but there is no sound, any help is much appreciated. thx again in advance rob |
Joined: 28 Dec 2006 Posts: 2878 Location: Overland Park, KS
Posted: Wed Jan 25, 2017 7:55 am Post subject: |
Welcome.
Check the voltages coming from your power supply, but this sounds like a main board failure. |
huntertownsen
Posted: Wed Jan 25, 2017 9:06 am Post subject: |
Thx for the advice , do you have any idea where i could get a pin out for this thx again rob |
huntertownsen
Posted: Wed Jan 25, 2017 9:37 pm Post subject: |
Update i tested the power board and i have all the correct output voltages, when i used the nuetral bar as a negative for the meter, at both ends of the ribbon, i then tested the ground points. on one i had 0 resistance, on the other i had 1.3 k ohms??? suggestions would be appreciated thx rob |
Posted: Thu Jan 26, 2017 11:22 am Post subject: |
I don't really understand what you're describing. Perhaps a picture would help. |
huntertownsen
Posted: Fri Jan 27, 2017 12:39 pm Post subject: |
http://imgur.com/FeZOaty
Sorry for the post , trying to see if that works[/url][/code] |
Posted: Mon Jan 30, 2017 12:52 pm Post subject: |
looks like bad tab bonds on the panel. Do they do anything if touch the ribbon cables? |
huntertownsen
Posted: Mon Jan 30, 2017 1:42 pm Post subject: |
no , i havent and ty, i thought bad bonds made horizontal lines, but im still learining |
huntertownsen
Posted: Mon Feb 06, 2017 2:17 pm Post subject: |
The screen appears to be fine, any other suggestions , thx rob |
