LG Electronics 47LN5700 - No video, Sound Ok
SammySan
PostPosted: Mon Jan 18, 2016 4:48 pm    Post subject: LG Electronics 47LN5700 - No video, Sound Ok Reply with quote
the make and model of equipment:
I have a LG Electronics 47LN5700 47-Inch 1080p 120Hz LED-LCD HDTV with Smart TV (2013 Model)
describe the symptoms:
black screen - no picture
describe any other information that may help someone help you.
I can see TV menus using a flashlight pointed at screen; Sound working fine too. But no picture though.
I opened up the TV and here are 3 boards on it:
https://drive.google.com/open?id=0B7zzEtRgwJ9yb3dTQTN1YjM4OFk
If you need to see a more focused closer picture for diagnosis, please let me know and I will upload it here.
PostPosted: Mon Jan 18, 2016 5:42 pm    Post subject: Reply with quote
And your customer back light controls are still at maximum??, as they have been since day one, when set was new??
Try unplugging PS to Main board cable and see if panel comes on. Otherwise you'll need to observe if ALL LEDs are attempting to come on. They are in series and if even one is defective it will prevent rest from lighting.
SammySan
PostPosted: Tue Jan 19, 2016 2:32 pm    Post subject: Reply with quote
it's my own TV and not a customer.
Lookin at the pictures does any of those bords look bad and need replacement ?
Or problem is somewhere else
What should I do at this point for diagnosis ?
PostPosted: Tue Jan 19, 2016 3:23 pm    Post subject: Reply with quote
Can you find any backlight controls among them? and if so, what do they label control(s)? and where are each set?
Boards pass. The limits of your picture resolution 'look' test anyway. The fact that we have no x-ray vision to tell if fuses are blown, nor the condition of any part that doesn't obviously 'look' bad not-with-standing.
Some more on similar: http://www.tv-forums.com/cgi-bin/gforum.cgi?do=search_results&search_forum=all&search_string=LN5700&search_type=AND&search_fields=sb&search_time=&search_user_username=&mh=50
