lines at top of screen
tompeters
PostPosted: Tue Mar 31, 2009 10:43 am    Post subject: lines at top of screen Reply with quote
rca 27 inch. replaced the la7837 ic, that took care of my problem. now i hav some horizontal lines at the top of the screen,what should i look at next ? i will note i have limited electonic exp. i can use a meter and replace parts. any help on what to look for? thanks
PostPosted: Tue Mar 31, 2009 1:34 pm    Post subject: Reply with quote
What was "original" problem?
Model / Chassis Number could help.
Check electrolytic capacitors in same general area as IC (usually 100 to 220ufd).
tompeters
PostPosted: Tue Mar 31, 2009 3:56 pm    Post subject: lines at top of screen Reply with quote
sorry i forgot to list numbers. rca model t25061gy ,chassis km257. origanal problem was vertical squash i think it is called. one line horizontal line in middle of screen. i first tried resoldering, then ordered new part,installed and now have lines at top of screen. thanks for the quick reply.
PostPosted: Tue Mar 31, 2009 6:21 pm    Post subject: Reply with quote
First its a 25" (Not 27") combo.
Try lytics as I mentioned earlier.
tompeters
PostPosted: Tue Mar 31, 2009 9:07 pm    Post subject: lines at top of screen Reply with quote
thanks for your help, i will not get to checking these out until tomorrow. see i somehow forget numbers. 25 " i will get back to you when i get these checked out. again thanks . tom
tompeters
PostPosted: Fri Apr 10, 2009 4:15 pm    Post subject: lines at top of screen Reply with quote
finally got a chance to get back to the tv . i was checking around the caps close to the vertical ic and the largest one behind it i chose to try to resolder again as the more closely i looked , the solder joint looked suspect. even tho i had resoldered several joints in that area i may have overlooked this one. i took it out and put it back in . i did not check it first ,but after resoldering it i have no more lines on my screen . thanks for your patience . without your help i would just have a bunch of extra parts in a big black box. my grandaughter is going on 6 and she loves to watch clifford the big red dog on that set .thanks again for your help.
PostPosted: Fri Apr 10, 2009 5:05 pm    Post subject: Reply with quote
You're welcome.
