muckmail
Posted: Tue Jun 11, 2013 5:57 pm Post subject: Magnavox 37mf231d/37 blinking light, no video |
I have a 37mf231d/37 HDTV that has a blinking light went I turn it on.
There is no picture. Form my internet reasearch I think it might be
bad caps in the power supply,
How do I open the thing without breaking the enclosure? Is there
anyone that could walk me through this type of repair? I figure it will
take several post before I can figure if it is worth repairing this TV
Thank you, |
muckmail
Posted: Thu Jun 13, 2013 9:40 pm Post subject: |
I have the set apart and I have the power supply.
Now I need to be able to tell which caps are bad.
Is there a way to do that?
Thank you, |
Posted: Fri Jun 14, 2013 8:40 am Post subject: |
Found - May or may not apply to yours:
Here's the service bulletin. Replace the Scaler or Main board. But check for voltages at plug 1503 on scaler and plug 1089 on power board.
DATE: January 8, 2007
Chassis: TPE1.0U LA, TPE1.0U PA
Model(s):
26MF231D/37 26MF231D/37B
32MF231D/37 32MF231D/37B
37MF231D/37 37MF231D/37B
37MF321D/37 37MF321D/37B
37MF331D/37 37MF331D/37B
42MF231D/37 42MF231D/37B
Symptoms:
? TV will not start up (appears dead, but the front panel LED may light)
? TV will shut down after warming up
? No color
? Loss of color after warming up
? No or poor audio
? Poor picture
Cause: For the production date code ranges listed below, the output of Crystal 1H00 for the Viper IC on the Small Signal Board reduces in amplitude and/or the crystal oscillator stops oscillating.
26MF231D with date codes of 624 or lower (BZxxx624xxxxxxxx or lower).
32MF231D, with date codes of 626 or lower (BZxxx626xxxxxxxx or lower).
37MF231D, 37MF321D, and 37MF331D with date codes of 623 or lower (BZxxx623xxxxxxxx or lower).
42MF231D, with date codes of 631 or lower (BZxxx631xxxxxxxx or lower).
Solution: Replace crystal 1H00 with a new type, part number 823827736071.
Replace capacitors 2H08 and 2H09 with 4.7pF capacitors, part number 223886975478. |
muckmail
Joined: 28 Dec 2006 Posts: 2878 Location: Overland Park, KS
Posted: Mon Jun 17, 2013 2:23 pm Post subject: |
broken link. |
