Author |
Myer Guest
Posted: Sun Feb 04, 2007 3:29 am Post subject: Magnavox 37MF331D No picture - shuts down |
This set appears to not have the lamp bank lighting. No schematic on it to trouble shoot. Anyone got any ideas. It isn't listed in force32 either unless I need an update.
TIA
Steve |
fav Guest
Posted: Sun Feb 04, 2007 3:29 am Post subject: |
Symptoms:
• TV will not start up (appears dead, but the front panel LED may light)
• TV will shut down after warming up
• No color
• Loss of color after warming up
• No or poor audio
• Poor picture
Cause: For the production date code ranges listed below, the output of
Crystal 1H00 for the Viper IC on the Small Signal Board reduces in amplitude
and/or the crystal oscillator stops oscillating.
26MF231D with date codes of 624 or lower (BZxxx624xxxxxxxx or lower).
32MF231D, with date codes of 626 or lower (BZxxx626xxxxxxxx or lower).
37MF231D, 37MF321D, and 37MF331D with date codes of 623 or lower
(BZxxx623xxxxxxxx or lower).
42MF231D, with date codes of 631 or lower (BZxxx631xxxxxxxx or lower).
Solution: Replace crystal 1H00 with a new type, part number 823827736071.
Replace capacitors 2H08 and 2H09 with 4.7pF capacitors, part number
223886975478. See the attached photos for locations of the crystal and capacitors.
Favian |
sl122282
Posted: Thu Jun 12, 2008 9:49 pm Post subject: pictures |
I was hoping to see some pictures to boost my confidence. thanks. |
Joined: 28 Dec 2006 Posts: 2879 Location: Overland Park, KS
Posted: Fri Jun 13, 2008 5:49 am Post subject: |
You do realize this thread is over a year old, right? |
Joined: 22 May 2008 Posts: 600 Location: The Last Frontier
Posted: Fri Jun 13, 2008 7:04 pm Post subject: |
You are going to need all of the confidence you can muster because these
parts are NOT easy to install even by a by a skilled technician. If you
damage the board, a new one costs $147.84 net from a distributor
(207.49 Retail) plus a $150.00 core that you will have to eat if you
damage the old board.
Jesse |
Posted: Fri Jun 13, 2008 8:19 pm Post subject: |
Thanks for sticking up for me, but I don't know if all this is really necessary. I wasn't really ever offended. |
wild spot
Posted: Sun Aug 17, 2008 8:44 pm Post subject: |
If it's not too much to ask, I could really use the pictures/locations of the 2H08 and 2H09 capacitors. I looked all over the net and the circuit board. THANK YOU, in advance! |
davew808
Joined: 12 Oct 2008 Posts: 6 Location: Honolulu Hawaii USA
Posted: Sun Oct 12, 2008 6:34 pm Post subject: pictures |
Hello.. I seem to be having the same problem.. is there anyway i can get the info/photo's? your help will be greatly areciated.
Thank you very much |
bigdufus
Posted: Sun Nov 16, 2008 10:34 am Post subject: 37mf331d 37mf321d |
Check cap 2074 on the power supply board. It is probably
all bulged out. Replace with 2200uf 35volt, instead or 25volt.
No credit here found it on another site. Checked mine,
bingo!!! |
davew808
Posted: Sun Nov 16, 2008 5:02 pm Post subject: Thank you |
Thanks.. looks like that may be my problem..
Thank you again |
