bassmaster
Posted: Sat May 13, 2017 4:22 pm Post subject: Magnavox 39me313v/f7 - no power |
I have a Magnavox model# 39me313v/f7 s/n ds3a1344136395, power board # ba3at0f0102 2 The unit does not turn on, it has no lights blinking or on, I have checked both boards for any obvious damage, found nothing, good power in and fuse is good. I've done minor repairs to other boards that had obvious caps blown, but I see nothing wrong here at all. Any help will be appreciated, Thanks . |
Posted: Sat May 13, 2017 7:29 pm Post subject: |
Sounds like Funai-made. If so, board should have voltage/test points marked.
See if any are present.
http://imgur.com/a/spGzw |
bassmaster
Posted: Sat May 13, 2017 8:06 pm Post subject: Magnavox 39 inch no power |
I have looked for voltage points and they are not marked on the board, I have played with other tv's that have had voltage points marked. Thanks for the flow chart I will look into that tomorrow. |
Posted: Sat May 13, 2017 8:22 pm Post subject: |
Take the blinders off.
Here is just one corner of the power board: http://imgur.com/a/xWXaD |
