Magnavox 42MF231D/17 42" plasma No picture, no sound
jrt896
PostPosted: Fri Dec 11, 2009 12:52 pm    Post subject: Magnavox 42MF231D/17 42" plasma No picture, no sound Reply with quote
Model 42MF231D/17
No picture, no sound and blue power button light. Replaced one bulging cap, no change. I saw the post about a 37" maggie and was curious if there is a pic of the suspect parts I could reference. Thanks all.
PostPosted: Fri Dec 11, 2009 1:51 pm    Post subject: Reply with quote
The previous post was about a LCD television. If the model number (/D17) you gave is correct you have a plasma tv. A LCD tv is /D37 in the model number.
If you indeed have a /D17 check the VS and VA voltage on the power supply for coming up even for a little while when powering up.
jrt896
PostPosted: Fri Dec 11, 2009 2:10 pm    Post subject: Reply with quote
yes, it is a plasma. I will check the voltages after work tonight. Do you have an idea of what they should read?
PostPosted: Fri Dec 11, 2009 2:14 pm    Post subject: Reply with quote
The values will be on a sticker on the panel itself as to what the levels of the VS and VA voltages should be.
jrt896
PostPosted: Fri Dec 11, 2009 2:15 pm    Post subject: Reply with quote
ok,
I had my roommate test them.
VS comes up at 204vdc
VA reads 70.3vdc
These are within the range posted on the board
vs 195 -215
VA - 50-70
jrt896
PostPosted: Fri Dec 11, 2009 2:56 pm    Post subject: Reply with quote
I should note that the cap I replaced was C5040 on what I believe is the Y main board. I still have a faint smell coming from that area as well
jrt896
PostPosted: Sat Dec 12, 2009 12:38 pm    Post subject: Reply with quote
Upon further investigation, I have found a burnt out component on the Y upper board (U5405). Coincidently, this is the smell I mentioned earlier. So, now I was wondering if there is a way to test the Y main without having the new Y upper. I just want to be sure I don't ruin my new board. Any tips would be greatly appreciated
tv2011
PostPosted: Fri May 20, 2011 5:00 pm    Post subject: plasma tv no picture no sound blue light on Reply with quote
Hi jrt896 i was wondering if you ever found out what was wrong with your tv? i know it was a long time ago i have the same problem with mine i get a faint smell and sound like a zapping electric current
please let me know if you fixed yours
THANKS!
