MAGNAVOX 9P5531 C103 PTV835 video blooming
DJING_2004
PostPosted: Mon Jan 18, 2010 1:24 pm    Post subject: MAGNAVOX 9P5531 C103 PTV835 video blooming Reply with quote
Screen shrinks and expands - may or may not correct itself after the TV warms up. After a few days, weeks, or months of having the shrinking/expanding problem you may loose all audio/video but the power light will remain lit!
No Audio or Video but power light is on (Note: This symptom typically occurs after having the expanding/shrinking screen problem)
Audio works but no Video. Power light still works.
No Video. Audio is intermittent. Power light still works
HELP ME FIX TV
THANK U EDDIE :arrow:
PostPosted: Tue Jan 19, 2010 12:31 pm    Post subject: Reply with quote
Please carefully recheck your model number or post a chassis number both of which will be on the sticker on the back.
The number supplied does not compute.
DJING_2004
PostPosted: Tue Jan 19, 2010 11:14 pm    Post subject: Reply with quote
IT SAYS CHASSIS # PTV835
YEAR 2001
MAGNAVOX
PostPosted: Wed Jan 20, 2010 8:16 am    Post subject: Reply with quote
Im guessing that model number should be 9P5531. I'll fix the title for you.
PostPosted: Wed Jan 20, 2010 12:19 pm    Post subject: Reply with quote
If the shrinking and expanding is an instantanious event (back and forth in an instantanious fashion) you most likely have a bad connection on the deflection pcb.
You do not say if the expanding is vertical or horizontal. Vertical = shrinking and expanding from top and bottom of screen and horizontal = left and right sides of screen.
Or is the event both?
Or is the event a slow transition from one to the other like a person breathing.
