Magnavox model MS3250 C321 Chassis 32T800 7629 Problem
marongec
PostPosted: Wed Aug 05, 2009 2:08 pm    Post subject: Magnavox model MS3250 C321 Chassis 32T800 7629 Problem Reply with quote
Model: MS3250 C321
Chassis: 32T800 7629
Serial: 77488632
When the television is turned on, the picture comes on very dark and distorted for approximately 15 seconds and then the screen goes out. The power light does stay on. I have not tried anything yet...just trying to see if anyone can give me a clue as where to start.
Thanks,
Chad
PostPosted: Fri Aug 07, 2009 9:35 am    Post subject: Reply with quote
Try C2455 47ufd@25V
If G2 is too high or low the IK circuit will shut the set down.
marongec
PostPosted: Sun Aug 09, 2009 9:54 am    Post subject: Reply with quote
I found C2455. Is there an actual test point to check the voltage or do I need to check it on the actual capacitor?
CM
PostPosted: Sun Aug 09, 2009 10:10 am    Post subject: Reply with quote
You need to take that one out and install another one with the same ratings and see if solves your problem. Take note of Polarity!
Mark G2 (knob on flyback) and move it down (CCW) about 6 degrees and see if that helps. Some controls were very touchy and had a "sweet spot." If no effect line control back to your mark.
Now if you're sure control was never touched I'd try cap 1st.
