Magnavox RS2555 Bending of text   Goto page 1, 2  Next
John1397
PostPosted: Sat Nov 27, 2010 7:45 am    Post subject: Magnavox RS2555 Bending of text Reply with quote
Does anyone know what section and what components might cause bending of a picture on a television screen when the writing is applied to the picture as I have a set that has good picture until writing is applied then the part with the writing looses it's hold? I am assuming do not look in the power supply section.
John
PostPosted: Sat Nov 27, 2010 8:46 am    Post subject: Reply with quote
model number... or we start making smart comments.
PostPosted: Sat Nov 27, 2010 12:16 pm    Post subject: Reply with quote
Strike up the "Brand."
John1397
PostPosted: Sat Nov 27, 2010 6:31 pm    Post subject: Model # Reply with quote
Magnavox RS2555 25" CRT Manufactured October 1992
PostPosted: Sat Nov 27, 2010 7:01 pm    Post subject: Reply with quote
C432 100ufd 200 volt in the power supply. Cool
John1397
PostPosted: Mon Nov 29, 2010 4:27 pm    Post subject: Reply with quote
It might have worked except seems I created another problem as the set will not start up not even any clicking noise the power button to the circuit board still is making contact. Must have broken something by sliding and maybe twisting the circuit board a little. I do not know that even if I had a diagram that I could repair it. Looks like another junker.
John
PostPosted: Mon Nov 29, 2010 4:58 pm    Post subject: Reply with quote
check all your connectors, the main fuse and the power supply.
PostPosted: Mon Nov 29, 2010 6:54 pm    Post subject: Reply with quote
Try looking for a crack in the main board where you twisted it. Also check R432 1K.
John1397
PostPosted: Tue Nov 30, 2010 2:31 pm    Post subject: Reply with quote
I would assume test point voltages that they give are when the tv is on and working not in just plugged in and turned off?
PostPosted: Tue Nov 30, 2010 2:48 pm    Post subject: Reply with quote
that depends on the section of the board. If it is plugged in, the primary power supply is active, and you should have some standby voltages as well.
Goto page 1, 2  Next
Page 1 of 2
