magnavox TS2572 C204
allmine1414
PostPosted: Sun Apr 12, 2009 1:26 am    Post subject: magnavox TS2572 C204 Reply with quote
Horizontal Lines happen intermittenly but i have good sound ....it happens most when either i change channels or when i turn on set... any ideas?
PostPosted: Sun Apr 12, 2009 12:20 pm    Post subject: Reply with quote
Does it happen on External Inputs too? (Assuming your set has any)
allmine1414
PostPosted: Sun Apr 12, 2009 1:27 pm    Post subject: Reply with quote
yes it still does....it happens when i turn it on and once it warms up(5-10mins) then it goes in and out...the pic will go back out with lines almost like it wants to reconnect but cant...then after a few mins , the pic will come back for awhile before it goes to lines again.....the sound is still good
PostPosted: Sun Apr 12, 2009 4:01 pm    Post subject: Reply with quote
It sounds like your set has a bad solder joint (or other bad connection).
If lines only happened while on "stations," and NOT on external input(s), I'd suspect a joint or joints inside the tuner.
But since you reply that it occurs with BOTH Tuner AND External inputs, it could be a joint anywhere in the set. I'd start with power supply area, then Vertical, Scan-derived supplies and even check CRT board joints.
