missgabibelly
Joined: 17 Oct 2009 Posts: 2 Location: Southern California
Posted: Sat Oct 17, 2009 12:44 pm Post subject: Magnovox, 42MF237S/37 |
1. Make & Model Number: Magnovox, 42MF237S/37
2. Current symptoms: clicks, green lcd blinks
3. Any symptoms that led up to the current symptom:
4. Location: middle
5. Any other details that may be helpful:it used to let us unplug till next day then plug back in and work |
missgabibelly
Posted: Sat Oct 17, 2009 9:16 pm Post subject: |
this is weird, I plugged in the tv and turned it on and now it works fine!! Will it continue this clicking and green light stuff it is doing. Should I keep it turned on all the time? |
Posted: Sun Oct 18, 2009 4:57 pm Post subject: |
Just as bad to let play all the time. Especially Plasmas.
Open up set and look for anything obvious. Power supply board is a likely culprit. Look for puffed electrolytic capacitors especially, burnt/discolored areas/parts, loose/ misaligned/unplugged cables, etc.  |
