Memorex MLT3221- Scan Error on Air - No Channels Cable
frafreg
PostPosted: Mon Dec 16, 2019 8:29 am    Post subject: Memorex MLT3221- Scan Error on Air - No Channels Cable Reply with quote
I am able to scan up to about 29% when using the antenna but no longer finds channels on cable. I replaced the main board and I still have the same problem.
Was there a known problem with tuners for this set or could I have just been unlucky enough to get another main board with the exact same problem?
Are there any tuner tests I can run or a procedure I can use to verify the tuner is the problem?
The tuner module on the main board is a Phillips FQD1236/F H-5. A new one is $15.
Thanks in advance for any help. Much appreciated!
Frank
