bigchris29
Posted: Sat Jan 24, 2009 8:49 pm Post subject: memorex mt2024 has picture but not bright? |
i have a memorex mt2024 that i bought my daughter. it lasted a couple of years, then the picture went dark. i can see the picture and hear the sound however it is not bright... i have tried to adjust all the setttings, as far as i can see all of those change the picture like they should, but the picture is not bright. is there a bulb that may need to be replaced? and if so how much of a job is it to do for a do it yourselfer?and where would i be able to get the parts i need to fix it? thank you in advance for all the help. |
bigchris29
Posted: Sun Feb 01, 2009 8:32 pm Post subject: i need help |
please i really cant afford to buy a new tv is there anyone out there that can help me? |
Posted: Sun Feb 01, 2009 9:32 pm Post subject: |
If set was working one day and not working the next (and set was not dropped or sabotaged), a part has probably failed.
All I can suggest is opening set and if nothing obvious (foreign material inside set, cracked board, etc.) you could try increasing Screen control on the flyback transformer.
bigchris29
Posted: Mon Feb 02, 2009 6:28 pm Post subject: thank you |
ok thank you i will check it out tonight and post my results thanks again.... |
