Mitsubishi CK2607R Completely Dead
Fairbanks-Morse
PostPosted: Wed Dec 25, 2013 10:22 pm    Post subject: Mitsubishi CK2607R Completely Dead Reply with quote
Mitsubishi 25" TV
Model CK2607R
Chassis UM2-B
Production year 1990
It's completely dead. TV shut off in the middle of watching with no prior warning or symptoms. Remote won’t turn on the TV and using the power button on the front panel does nothing.
The two internal fuses tested good with a continuity test.
Any suggestions would be welcome.
PostPosted: Wed Dec 25, 2013 11:08 pm    Post subject: Reply with quote
130VDC across C957?
Fairbanks-Morse
PostPosted: Thu Dec 26, 2013 7:59 am    Post subject: Reply with quote
Suggestion was:130VDC across C957?
I don’t have a background in TV repair (Prior jet engine technician) so I could use some interpretation. Is this suggestion recommending checking the 130VDC power source on position C957 on the main circuit board? Possible cold solder joint or is this a test to identify a faulty power supply?
PostPosted: Thu Dec 26, 2013 8:46 am    Post subject: Reply with quote
You will need to be able to identify the different components, to safely test for voltages at specified points and be able to unsolder, test and/or change basic parts and solder them back. Google and YT should provide guidance.
I got a little ahead of myself. There is NO relay click? Right? Then will be No voltage across C957.
You'll (still) need a DVM (set to DC Volts). Across C3A0? Across C2A0?
Fairbanks-Morse
PostPosted: Thu Dec 26, 2013 9:24 am    Post subject: Reply with quote
Thank you for taking the time to respond to my posts. There is no relay click. There is a transformer mounted to the left of the main circuit board part number 350P43902 TRANSFORMER 24F049HD which I found online here:
http://www.hbfelectronics.com/index.php?action=disp_item&item_id=294136
The transformer is supplied by one pair of thick gauge white wire with an output to two smaller red wires. I suspect this transformer may be dead. I could check both input and output but could you tell me what DC voltage setting to use on the smaller red wires?
Thank you.
PostPosted: Thu Dec 26, 2013 10:14 am    Post subject: Reply with quote
At transformer wires it will be AC VOLTS.
Primary (thicker whites) = 120 VAC
Secondary (thinner reds) = approx 20 VAC
IF you were to have a DVM (set to DC Volts) and measure Across C3A0 (and obtain 21.5 VDC) & measure Across C2A0 (and obtain 12 VDC.)
EITHER will prove the transformer is O.K.
Fairbanks-Morse
PostPosted: Thu Dec 26, 2013 12:06 pm    Post subject: Reply with quote
Thanks for taking the time to reply! I slid the main circuit board out of this 23yr old Mitsubishi TV and found a cold solder joint just under the relay. Problem solved! Perhaps it will last another 23yrs so I can will it to my great, great grandchildren.
