MITSUBISHI CS-2015R
Chief
PostPosted: Sat Jul 05, 2008 6:53 am    Post subject: MITSUBISHI CS-2015R Reply with quote
Very weak audio output.
I replaced the AF output amplifier LA4270 but no any change.
Has anybody the schematic?
andydevit
PostPosted: Sat Jul 05, 2008 7:54 pm    Post subject: Reply with quote
Could be the speaker itself dry rotted , I've had to replace them on that brand before,
also might be about the vintage that had the infamous conductive
glue. Look on both sides of the board for a brownish glue. It becomes
conductive over the years leading to almost any kind of random
failure. Eventually it can even corrode the copper traces.
Remove all occurances thoughly
PostPosted: Tue Jul 08, 2008 11:05 am    Post subject: Reply with quote
Chief,
IF there is no or low signal at IC201 Pin 4 check for open L300. (Located on main PCB PT# 327P073020). Also check for a missing 6V at pin 39 of IC201. Check for a Shorted or leaky C335 (.01UF) off of Pin 39 of IC201 on the main pcb.
Hope this helps.
