Mitsubishi Service Menu Codes - Plasma, LCD, CRT, RPTV
Mitsubishi
PostPosted: Wed Jul 18, 2007 5:55 am    Post subject: Mitsubishi Service Menu Codes - Plasma, LCD, CRT, RPTV Reply with quote
# Using the remote control press:
{MENU} {0} {3} {5} {3} buttons.
{MENU} {0} {3} {5} {7} buttons.
# Then use {VIDEO} or {AUDIO} buttons to enter two different groups of adjustments.
# {VIDEO} and {AUDIO} steps along through the adjustments, and {+} {-} does the adjusting.
# Press the {ENTER} button to save the change.
# Press the {MENU} button twice to exit service menu.
Mitsubishi
PostPosted: Wed Jul 18, 2007 5:57 am    Post subject: 2nd Method Reply with quote
{MENU} {1} {2} {5} {7} buttons.
{MENU} {1} {2} {5} {9} buttons.
{MENU} {1} {3} {7} {0} buttons.
Mitsubishi
PostPosted: Wed Jul 18, 2007 5:58 am    Post subject: 3rd Method Reply with quote
{MENU} {2} {3} {5} {6} buttons.
{MENU} {2} {3} {5} {7} buttons.
{MENU} {2} {3} {5} {8} buttons.
{MENU} {2} {3} {5} {9} buttons.
* Then use {VIDEO} or {AUDIO} buttons to enter two different groups of adjustments.
* {VIDEO} and {AUDIO} steps along through the adjustments, and {+} {-} does the adjusting.
* Press the {ENTER} button to save the change.
* Press the {MENU} button twice to exit service menu.
Mitsubishi
PostPosted: Sat Jul 21, 2007 2:09 am    Post subject: Service Menu Key Sequence Reply with quote
{MENU} {8} {2} {5} {7} buttons.
Mits VZ8 chassis Menus
Option menu, Menu 1270
Service Menu, Menu 1257
Convergence Menu, Menu 1259, 4 Fine,
5 Coarse, 6 Misc.
