Mitsubishi VZ8 VS-70707 will not turn on
weldon
PostPosted: Thu Jan 24, 2013 4:05 pm    Post subject: Mitsubishi VZ8 VS-70707 will not turn on Reply with quote
Replaced C411 and C412, plugged in, green LED blinked three times, turned on and TV played 4 hours. Turned on and off a few times and TV played. Now TV will not turn on, green LED blinks once, relay clicks, error code blinks 24. Test voltage; Between R510 and D544 - 6.8V, #1 on DB connector - .53V, #1 to #2 on IC935 - .5V, #3 to #2 on IC935 - .5V, F904 - 18V, #2 on PC951 - 9.4V, 13,14 on T951 - 119.8V, Between R914 & D977 - 30.4V, TP4V - 6.22V, TP12V - 11.9V, #1 to #3 on IC952 - .3V, #2 to #3 on IC952 - 9.4V, F902 - .3V, #3 on PC951 - 57.9V, R956 - 59.8V, F903 - .0V, Between D970 & C923 - 6.2V, #2 on T501 - .3V, Between D974 & C978 - 18V, Between #2 on IC503 & #5 on PC393C - .6V, D520 - .0V, R557 - .6V, D971 - .3V, R956 & R955 - 60.1V. No voltage at T501. Where to begin in replacing parts.
