Plasmaman
Posted: Tue Feb 01, 2011 1:20 pm Post subject: |
Wow what an old post with no reply's. Well I have tore down and fixed up about five of these sets. I have found that in order to clean up the picture noticeably you need to clean the lens, the mirrors (usually lots of dust hiding here) the lenticular lense (both sides) and both sides of the diamond shield as well. The diamond shield is easily removed by bowing the shield. It has three plastic clips on each side, pop the shield from the center and work your way out, then bow the shield and pop the top out, it should lift up and out after that. From there you can remove the four black screws across the back of the set in the rear, and the three screws going down each side in the rear. That will allow you to remove the lenticular lense, pull it up and out. You will need to disconnect the wire harness at the bottom of the screen that connects the menu, vol buttons ect. With the lenticular lense out the set will be basicly hollow and you can vacuum out all the dust, (I've seen spider webs in here that cause shadows on the screen) and wipe down all the mirrors. If you wipe the projector lense I would recommend a nice LCD cloth and be extra careful, as your not really supposed to touch it. Clean the set out carefully and re assemble it in reverse order. From there turn on the set, select ant-dtv input no signal, press tv menu 2-4-5-7 in sequence, press rewind to activate test pattern, press audio to select FMT function, use video button to select 1 HPOS, use adjust buttons to adjust picture horizontally, press enter to save the adjustment, use video button to select V POS, use adjust button to center the picture vertically, press enter to save the adjustment, DO NOT set the V POS adjustment data to 0 or 255 and press enter or the video will be muted and the onscreen will no longer be visible. Press home or tv menu twice to terminate the adjustment mode. You may not need to enter the service mode after you clean out your set, but is is nice to generate the test pattern just to check the alignment of the picture. Should you need to rotate the picture, you would make a mechanical adjustment of the brass screws close to the light engine. Horizontal and vertical keystone adjustment's are mechanical as well. Usually not needed unless your set has been moved alot, but again it's real easy to just enter the service mode and generate the test pattern as see exactly what you've got. The test pattern will look like a crosshair pattern with three border squares around it, it should be centered on the screen and the borders all equal. Should take you an hour or two, but you'll be happy with your results. |
