Mitsubishi WD-92840 DLP - blinking light 8 yellow, 4 red   Goto page 1, 2  Next
drjones3000
PostPosted: Wed Aug 03, 2016 5:02 am    Post subject: Mitsubishi WD-92840 DLP - blinking light 8 yellow, 4 red Reply with quote
I have a Mitsubishi WD-92840 and the front light blinks 8 yellow times an 4 red times does anyone know what that code means? Thanks
drjones3000
PostPosted: Wed Aug 03, 2016 1:20 pm    Post subject: Reply with quote
Wd 92840 serial 102827
PostPosted: Wed Aug 03, 2016 1:46 pm    Post subject: Reply with quote
Error code 48:
"PON-SHORT 3.3V or 5V switched supply short PWB-MAIN Failure"
Indicating a power-on short of one of those voltage lines.
I found the service manual here: https://is.gd/wxc9tL
drjones3000
PostPosted: Wed Aug 03, 2016 2:00 pm    Post subject: Reply with quote
Thanks alot do u know if its a diy type of fix
PostPosted: Wed Aug 03, 2016 2:13 pm    Post subject: Reply with quote
I guess it depends on what you feel comfortable doing. I was only able to find a replacement here, on ebay
That seems pretty high for a power supply, but it's the only one I found available from a quick glance.
PostPosted: Wed Aug 03, 2016 2:56 pm    Post subject: Reply with quote
PWB-MAIN does NOT equal Power Supply. Two different items.
drjones3000
PostPosted: Wed Aug 03, 2016 3:05 pm    Post subject: Reply with quote
Ok thanks alot
drjones3000
PostPosted: Thu Aug 04, 2016 11:44 am    Post subject: Reply with quote
What part is thePWB-MAIN?
PostPosted: Thu Aug 04, 2016 3:28 pm    Post subject: Reply with quote
Bearing in mind that you have WD-92840 and manual is for WD-92842. I don't care how similar they are, go with the part number on the actual part.
Page #39 Boards drawing.
Page #40 Boards Parts Numbers.
Page #9 Boards removal.
drjones3000
PostPosted: Thu Aug 04, 2016 5:31 pm    Post subject: Reply with quote
I found an downloaded the manual but cant find part numbers or anything in it
Goto page 1, 2  Next
Page 1 of 2
