Dee Guest
Posted: Sat Jun 09, 2007 10:41 pm Post subject: Mitsubishi wd52525 lamp red light on - after lights up 3 sec |
Mitsubishi DLP WD-52525 lamp red light on (after lamp lights up3 sec). error code is 34 .After change light engine still the same. Need big help! |
Jim Guest
Posted: Sat Jun 09, 2007 10:41 pm Post subject: |
For error code 34, look for missing 5Vdc at J-9 connector (pins 1, 2) on
Engine Driver PCB. If missing may have to replace Power PCB. Should be
part # 930B921002.
Jim... |
Dee Guest
Posted: Sat Jun 09, 2007 10:42 pm Post subject: |
Thanks Jim . I found two CAP poped. After change them C9A38 C9A37
3300uF/10 then work good |
adschweda
Posted: Wed Dec 24, 2008 6:15 pm Post subject: Mitsubushi WD-52525 |
I have the same problem, but I have no idea what you are talking about... I want to fix it, I just bought a new bulb, what do I need to do? |
Dave
Posted: Tue Dec 08, 2009 7:16 am Post subject: Mitsubishi 52525 |
I am having the same problem and found the same 2 caps blown and noticed 3rd cap swollen as well ( C9A62), is this a power surge thing or has anyone discovered the root cause for these blown caps? |
Posted: Tue Dec 08, 2009 1:04 pm Post subject: |
Manufacturer's greed. "Build it cheaper" mentality. "With the voltage we expect at this point, we should use a 16 volt cap here, but we can save a tenth of a cent if we use a 10 volt." This combined with the power surge you mentioned... |
Posted: Tue Dec 08, 2009 7:27 pm Post subject: |
or if you're more of a conspiracy theorist, you could say that the TV will fail that much earlier, and they get to sell more TV sets that way... assuming you would buy the same brand again. |
