mitsubishi WD60638 (dlp set) color flickers after warmup
Wendell2014
PostPosted: Thu Feb 27, 2014 1:32 am    Post subject: mitsubishi WD60638 (dlp set) color flickers after warmup Reply with quote
mitsubishi WD60638 - color flickers after warmup.
had replaced color wheel as motor bearing where pooched, new color wheel is fine but the dlp set still has the same issue.
i have the service manual for this set and doesn't mention anything else about the problem
Chassis is v43 on the tv,i have ruled out everything else,expect maybe new color wheel is faulty
Wendell2014
PostPosted: Mon Mar 03, 2014 2:25 am    Post subject: Reply with quote
Been thinking about the issue and maybe the optical sensor for the color wheel is acting up, so i plan to scope that and hit with some freeze spray and if that clears it up then i will replace the sensor
