Olevia 232-S13 picture upside down
nick_99
PostPosted: Fri May 15, 2009 8:49 am    Post subject: Olevia 232-S13 picture upside down Reply with quote
Olevia model 232-S13 LCD
Hi all,
I replaced the original main pcb from my tv and now it is telling me to stand on my head to watch! Laughing picture is upside down.
I went through on screen menu but cant find any setting to invert the pic.
Can someone give a suggestion on what to do next? I am tired on bending my neck to read the screen. Smile I am about to take out some screws and turn the plastic panel upside down, but afraid I might run into more problems than I already have.
Shocked
PostPosted: Fri May 15, 2009 12:05 pm    Post subject: Reply with quote
Was that "Customer" On Screen Menu or "Service" On Screen Menu Question
What was the original problem that caused you to change the Main PCB?
nick_99
PostPosted: Fri May 15, 2009 12:10 pm    Post subject: Reply with quote
The original board was replaced because it wasn't working properly. After starting tv for a few minutes, picture was going off - dark screen. I had diagnostics done by local shop, and they said to replace the main pcb.
nick_99
PostPosted: Fri May 15, 2009 12:12 pm    Post subject: Reply with quote
Customer on screen menu. Sorry I'm not techy enough to get into service menu.
PostPosted: Fri May 15, 2009 12:22 pm    Post subject: Reply with quote
Well, that's where the screen flip adjustments would be. (I'll see if I can dig up the procedure)
Another alternative would be to locate and exchange EEPROMS (assumes original board setup is correct).
nick_99
PostPosted: Fri May 15, 2009 12:30 pm    Post subject: Reply with quote
Do you mean the original board setup did not have this problem and the pic was not upside down, then Yes.
I have the original board and I will look into locating EEEPROMS, assuming it is a chip?
PostPosted: Fri May 15, 2009 12:33 pm    Post subject: Reply with quote
Usually 8-pin DIP (Dual Inline Pin), most likely surface mount, **24C** (ie. 24C08, etc.).
beakerwsw
PostPosted: Sat Aug 04, 2012 10:30 am    Post subject: Reply with quote
Sorry to revive a wicked old thread, but I'm having the exact same issue, does anyone else know how to fix this?
TonyC1
PostPosted: Tue Sep 11, 2012 5:52 pm    Post subject: Flip the tv over Reply with quote
Just flip tv over :lol:
sorry could't resist
