panasonic CT-27D11E buttons no work
4uzindian
PostPosted: Tue Sep 14, 2010 3:46 pm    Post subject: panasonic CT-27D11E buttons no work Reply with quote
panasonic tv #CT-27D11E regular tv. the only button on the tv that works is the power . all the other ones won't respond. slid the circut board out and pushed with my fingers still nothing. no cracks or loose welds. tv responds with remote control. the reason i need the use of one of the tv buttons is to get into the service menu. explained of course from your website. i need to press the action button in one of the steps to open it. the reason is cause i had a tube 20" zenith running next to it. and the zenith just blew it away with it's brightness level. the brightness and contrast levels on the panasonic are all the way up. so i thought the service menu might have an adjustment for it. with comcast signal split to these two tv's the white's on the panasonic look light gray compared to the zenith. any thought's would be helpful.
PostPosted: Tue Sep 14, 2010 10:34 pm    Post subject: Reply with quote
Does a screwdriver blade shorting across switch's contacts work the function you desire?
4uzindian
PostPosted: Wed Sep 15, 2010 12:58 pm    Post subject: panasonic tv buttons Reply with quote
tryed a piece of wire on all didn't do anything.
4uzindian
PostPosted: Mon Sep 20, 2010 3:37 pm    Post subject: panasonic ct-27 buttons no work Reply with quote
i fixed the problem. thank's for your reply. i'll be closing this post now.
PostPosted: Mon Sep 20, 2010 9:58 pm    Post subject: Reply with quote
any hints on how you fixed it?
