Panasonic CT-27G24A - picture adjustments
tao101
PostPosted: Tue May 12, 2015 2:17 pm    Post subject: Panasonic CT-27G24A - picture adjustments Reply with quote
I just had the back off my 1999-era TV to resolder the s-video connector and was surprised there wasn't an array of potentiometers for adjusting the horizontal and vertical picture size, etc. Can anybody assist me with several minor picture issues?
1) The picture extends off the top and bottom of the screen by at least 1/2 inch in each direction.
2) The picture is bowed-in somewhat on each side...a "trapezoidal" problem?
3) There is a roughly 1/2 inch vertical "stripe" down the right side of the screen where the image is noticeably lighter.
BTW, I tried the code for "serviceman mode", but my TV doesn't have a setting for Antenna/Cable, and also no longer lets me tune channels at random. The channel up/down controls only step through a set of pre-programmed channels from before the switch to digital, and I'm stymied over how to turn this off.
Thanks for any suggestions!
PostPosted: Tue May 12, 2015 5:23 pm    Post subject: Reply with quote
Repair any problem(s) BEFORE making ANY adjustment(s).
https://www.manualowl.com/m/Panasonic/CT27G24A/Manual/128967
An Auto Search for channels with NO Antenna connected or manually erasing all one at a time should leave No channels left in memory.
tao101
PostPosted: Wed May 13, 2015 11:43 am    Post subject: Reply with quote
Thanks, I figured it out. When the TV is set to take its input from Video 1 or Video 2, the Antenna/Cable, Auto Program, and Manual Program options all disappear! In spite of what the manual says, I'd forgotten they were ever there. Will browse the serviceman options shortly.
Of the issues I listed, which would you classify as problems and which as adjustments?
PostPosted: Wed May 13, 2015 12:39 pm    Post subject: Reply with quote
First check ALL B-Plus sources for correct voltage values and no excessive ripple.
1) Anywhere between 1/4 & 1/2 inch is allowed (approx. 10% overscan).
2) You may want to confirm the resistance value of R760 Width potentiometer (5K) on the Z board (pincushion).
3) Check C555 in 220 volt line.
