Panasonic CT-27G3W Squealing sound then nothing
Curious George
PostPosted: Wed Apr 22, 2009 7:34 pm    Post subject: Panasonic CT-27G3W Squealing sound then nothing Reply with quote
Panasonic CT-27G3W
Chassis# ANEDP303
Completely Dead
Hello, and thanks for such a great website. I was not actually present at the passing of our dearly departed, but here is what I was told. When the TV was turned on there was a high pitched squealing noise but no picture. Then the noise stopped and there was a faint burning smell. The TV was immediately unplugged. I've been told the squealing sound may have happened on one or two other occasions before the set finally gave up the ghost.
Today I opened up the back of the TV and plugged it in. Nothing. No picture, no sound, no burning smell and no glow at the end of the picture tube. Unplugged TV, discharged CRT per your instructions and no expected "zap" sound. I even moved the ground around to be sure, still nothing. The one glass fuse I found tested good for continuity.
I can't tell you how glad I am I found your website. I learned how to discharge a CRT without killing myself! Any advice on this problem--even bad news--would be greatly appreciated. Regards.
PostPosted: Thu Apr 23, 2009 12:07 am    Post subject: Reply with quote
Start by checking the power supply and regulator. Also the horizontal output transistor. Regulator and transistor may fail together.
Curious George
PostPosted: Thu Apr 23, 2009 4:30 pm    Post subject: Reply with quote
Thanks for the reply. Unfortunately, your answer tells me I may have hit the limit of my abilities here. Even if I knew exactly where to test, I wouldn't know what values to look for. If the problem is in one of the parts/circuits you mentioned, is it worth repairing on a ten year old TV?
