Panasonic ct-27sx12 will not turn on
RickyJ
PostPosted: Sat Nov 13, 2010 5:45 pm    Post subject: Panasonic ct-27sx12 will not turn on Reply with quote
I have a Panasonic ct-27sx12 crt tv that no longer turns on. When I press the power button there is no noise or sound of any kind. The wall outlet works fine (I have tried 2 different outlets so I am confident that is not the problem). However, every time I tried a different outlet the TV made a clicking noise but never turned on. After the initial click on each new outlet there was no more clicking. The problem started up about a month ago while we were watching TV, it went off by itself. I changed outlets and it was fine for a couple of weeks. I changed outlets again and it was fine for over a week. Now the TV no longer turns on. I'm not sure if I want to open the rear panel and mess with it. If it sounds like a blown fuse I could handle that.
PostPosted: Sun Nov 14, 2010 12:04 am    Post subject: Reply with quote
It may involve a fuse, but if it does something in the power supply or horizontal output circuits will most likely be causing it to blow.
If you have a DVM, you might be able to perform some basic tests.
