Panasonic CT-31S18S no video
tvt
PostPosted: Mon Apr 05, 2010 5:58 am    Post subject: Panasonic CT-31S18S no video Reply with quote
Panasonic
CT-31S18S
AEDP242
At first the verticle collapsed, a horizontal line at the middle after the TV wamr up.
Resoldered the VERT region, checked capacitors, they seem alright.
However, no video now, a colored horizontal line (sometime a half line) only flashes at on/off.
C455, C451 C458, OK, D812, C810 OK.
Sound is still OK.
How do I test IC451 (LA7836)?
One more question, I cannot find schemtics for AEDP242, is it the same as AEDP246?
thanks.
tvt
PostPosted: Mon Apr 05, 2010 10:37 am    Post subject: Reply with quote
Make sure there's no "crator" in the face of that IC. Recheck your soldering for "bridges." Check B-Plus voltages pins 1 & 7.
What were capacitors "checked" with?
http://pdf1.alldatasheet.com/datasheet-pdf/view/40353/SANYO/LA7836.html
tvt
PostPosted: Tue Apr 06, 2010 7:29 am    Post subject: Panasonic CT-31S18S no video Reply with quote
I tested capacitors by a Fluke meter with C readings.
Most C measured at about the marked values on the board,
those not, I have taken them out and measured OK.
Checked VCC at pins 1 and 7 OK.
I guess something in the IC451, that turns the thermal protection on
and shut it immediately, but don't know why and how to fix.
Thanks.
