Panasonic CT-32SC14J completely dead
pintobean
PostPosted: Mon Nov 17, 2008 9:41 pm    Post subject: Panasonic CT-32SC14J completely dead Reply with quote
Panasonic 32" (200 pound) TV
Model No. CT-32SC14J
Chassis No. BP411
Serial No. ME42110156
Manufactured July 2004
Completely dead.
No response with remote or with tact switch on front of TV.
Opened case and am not sure where to start.
Small glass fuse looks good, not black and wire looks to be in tact inside.
My father-in-law had it repaired six months ago for same exact symptoms. Receipt says *repaired all bad connection at main board *check all over (I know this was vague at best)
thank you for any help you might offer
PostPosted: Tue Nov 18, 2008 12:06 pm    Post subject: Reply with quote
Symptom: Dead, no clicks, no LED
Check IC001 and IC005 pins 2&3 for low resistance (ohms).
IC001 is a 84 Pin flat pack mounted on the conductor side of the "A" board.
IC001 is a 4 pin ic mounted on the component side of the "A" board.
