Panasonic HDTV 10801 CinemaVision TV wont power up
fuzzykpd
PostPosted: Thu Oct 02, 2008 1:42 pm    Post subject: Panasonic HDTV 10801 CinemaVision TV wont power up Reply with quote
My 50 inch projection Tv started to power up the other day and then just shut down as the image was starting to appear on the screen. I made a few attempts with the same result and finally unplugged it fearing I could start a fire or cause more damage if left on. My son can do the repairs if we have some clue as the main problem and a PDF manual for the TV which I havent been able to find. Any ideas on where to start? The Tv has worked fine up to this point. Thanks Fuzzykpd
PostPosted: Fri Oct 03, 2008 11:04 am    Post subject: Reply with quote
The model you display does not match any model for Panasonic. Could you recheck and include complete number including any dashes please.
fuzzykpd
PostPosted: Fri Oct 03, 2008 11:43 am    Post subject: tv model Reply with quote
I just took the info off the front of the unit. it has a Panasonic Logo bottome center and upper left says CinemaVision. upper right has HDTV 10801. My son put the tv back against the all yesterday so I cant access numbers that were on the back that appeared to be serial vs model info. I will try to get it moved out again asap to update any numbers I find. thanks
