Panasonic LCD TV PT52LCX65-K green circular spot
Terry_
PostPosted: Thu Jul 17, 2008 11:20 am    Post subject: Panasonic LCD TV PT52LCX65-K green circular spot Reply with quote
(1) Hi, I have a Panasonic TV that has a green spot about 2-3 inches down from the top middle of the screen. The spot is circular like a spot light shining down from above. I haven't done any LCD sets before, so I'm kinda lost as to what makes them tick "so to speak". Any suggestions?
Eric_
PostPosted: Thu Jul 17, 2008 11:20 am    Post subject: Reply with quote
Terry see this..Eric
Replace the Light Engine Assembly.
This model has had alot of problems with it.
All you need to do to confirm it is ,look at the user menu or OSD.
If it looks abnormal also then the ENGINE is bad.
Dewayne
PostPosted: Thu Jul 17, 2008 11:21 am    Post subject: Reply with quote
You have a defective optical block.
