Panasonic PT-53WXD63G bad tuner?
Eddy64
PostPosted: Tue May 24, 2011 1:25 pm    Post subject: Panasonic PT-53WXD63G bad tuner? Reply with quote
I have a Panasonic PT-53WXD63G that will not display any picture or sound from the cable source. It will display PIP but no sound and the rest of the screen is black. It will play movies through the DVD player with great sound and picture. I suspect a defective tuner but I'm not sure.
PostPosted: Wed May 25, 2011 7:43 am    Post subject: Reply with quote
Unless you have a piece of TV test equipment that puts out ANY channel you desire, try it with a VCR, Atari or other item that outputs on channel 3 (or 4). Set TV on same channel.
Eddy64
PostPosted: Wed May 25, 2011 8:06 am    Post subject: Panasonic PT-53WXD63G Reply with quote
The cable source is good since I tested it with a working tv and the dvd player and xbox work correctly (sound and picture good) I'm not sure how else to trouble shoot this problem. I have the cable source hooked directly to the tv (A source) not throught the DVD or VCR. Is there a different way to test this problem?
PostPosted: Wed May 25, 2011 11:45 am    Post subject: Reply with quote
Your DVD's OUTPUT is connected to the TV's A/V inputs? or to the tv (A source)?
Eddy64
PostPosted: Wed May 25, 2011 12:26 pm    Post subject: Reply with quote
Yes DVD's OUTPUT is connected to the TV's A/V inputs. thanks
