Panasonic Guest
Posted: Wed Jul 18, 2007 6:01 am Post subject: Panasonic Service Menu Codes - Plasma, LCD, CRT, RPTV |
Panasonic TV's after 1996 can be set to "Serviceman Mode" with the
following remote control sequence:
-select the SET-UP icon and select CABLE mode.
-select the TIMER icon and set the SLEEP timer for 30 minutes.
-press the ACTION button twice to get out of the menus.
-change to channel 124.
-adjust the volume to minimum (0).
-Hit the VOL down button on the TV itself (not on
the remote) and a red "CHK" should appear in the upper corner.
-press the ACTION and VOLUME DOWN buttons (again, on the
TV, not the remote) you will toggle between AGING and SERVICEMAN modes.
Select Serviceman mode. The POWER button on the remote control will
select one of the five Serviceman Adjustment modes.
The modes are:
B - Serviceman VCJ SUB Adjustments. These include sub-tint,
sub-color, sub-brightness, sub-contrast, colorkiller/ABL/gamma,
audio and video adjustment, and vertical size.
C - Serviceman VCJ Cut-off adjustments. These include Red, Green
and Blue cut-off, red and blue drive, automatic fine tuning
(AFT), RF AGC (RF gain control), horizontal center, beam limit,
etc.
S - Serviceman Options Adjustments. These involce the PIP and
clock.
M - Serviceman MTS (Stereo/SAP) adjustments.
CHK - the mode you first entered. Normal picture and sound, lets
you check things over and still have a hotkey into the
service menu.
There is one more adjustment that isn't in the five modes, it's
global. When in either the yellow or red CHK mode, you can press
RECALL on the remote control to enter the purity field check mode.
This lets you select a pure white, red, green, or blue screen. A
good thing to walk away from if you just want to temporarily freak
out the floor manager, but it will be fixed as soon as the TV is
turned off. Oh well.
To get out of Serviceman mode, press ACTION and POWER on the
receiver simultaneously for at least 2 seconds. The TV will momentarily
shut off and then comes back on.
PE77U / PX75U / PX77U / PZ700U / PZ750U
PD60U / PX6U / PX60U / PX600U
PD50U / PX50U / PX500U :
* Hold down the {VOL -} button ON THE PLASMA TV.
* Press the {RECALL} button 3 times on the remote.
* The Service Menu will be displayed.
* Use {1} {2} on remote to navigate main menu items.
* Use {3} {4} on remote to navigate sub-menu items.
* Use {VOL+} {VOL -} on remote to change item value.
* Write down all values before changing
Once a value is changed, THE CHANGE IS MADE.
* Power off to exit service mode and save. |
Panasonic Guest
Posted: Wed Jul 18, 2007 6:01 am Post subject: |
PA25UP / PD25UP / PX25UP :
* Using the remote control:
* Press the {MENU} button.
* Set "Antenna A" to "Cable".
* Select "Timer" menu and set sleep timer to 30 min.
* Press {OK} twice to exit menus.
* Tune to channel 124.
* Press and hold {VOL -} button ON THE PLASMA TV.
"CHK" appears in on top-left corner followed by 5 letter/numbers
(which are the cumulative hours in hex numbers)
* While the "CHK" is displayed, press the {OK} and {VOL+} buttons
ON THE TV simultaneously to toggle between Modes:
 Red "CHK" for Serviceman  Yellow "CHK" for Aging â€â€
* Press the {POWER} button on the remote to select one of the six
Serviceman Adjustments Modes.
A. MTS ADJUSTMENT
B. CLOCK ADJUSTMENT
C. VIDEO ADJUSTMENT
D. HDEF ADJUSTMENT
E. VDEF ADJUSTMENT
F. DAF ADJUSTMENT
G. OTHER ADJUSTMENT
* Press {CH+} {CH -} on the remote to select the settings
on each of Service Adjustment Modes.
Write down the original values before modifying anything.
It's easy to erroneously adjust the wrong item.
* Press {VOL+} {VOL -} on the remote to change values.
* Press the {POWER} button on the TV to exit the service menu. |
Panasonic Guest
Posted: Wed Jul 18, 2007 6:02 am Post subject: |
PA20UP / PX20UP :
* Press "Setup" menu.
* On "Mode" menu, select "Cable"
* Press {ACTION} twice to exit menus.
* While the "CHK" is displayed, press the {ACTION} and {VOL+} buttons
A. MTS ADJUSTMENT
B. CLOCK ADJUSTMENT
C. VIDEO ADJUSTMENT
D. HDEF ADJUSTMENT
E. VDEF ADJUSTMENT
F. DAF ADJUSTMENT
G. OTHER ADJUSTMENT
Panasonic Guest
LCDs / CRTs / RPTVs :
* Hold down the {VOL -} button ON THE TV.
Model PT45LC12:
1. Press and hold Vol Dn on center panel and press recall button on remote until Work Mode is displayed on screen.
2. Press and hold Vol Dn on TV and Swap button button on remote until Factory Adjust is displayed on the screen
3. Use Channel Dn button to select Digital and press the Action button. |
Panasonic Guest
Posted: Wed Jul 18, 2007 6:03 am Post subject: |
PROJECTORS :
* Go to "Options" menu.
* Highlight "OSD".
* Then press and hold the {ENTER} button,
until the Service Menu is displayed.
* Press the {MENU} button to exit. |
Panasonic Guest
Posted: Wed Jul 18, 2007 6:04 am Post subject: |
PROJECTORS:
# Turn the Projector on.
# Press the {POWER} button.
# A "Power Off" confirmation will come up on screen.
# Then press {LEFT} {UP} {DOWN} {UP} {DOWN}
& {ENTER} buttons.
# The Service Menu will be displayed.
# To exit, turn the Projector Off. |
Panasonic Guest
PLASMAS 8UK / 9UK:
* Hold down the {VOL -} button ON THE PLASMA DISPLAY.
* Press the {STATUS} button 3 times on the remote.
(Status button is the one above Setup button)
* The Service Menu (CAT) will be displayed.
(CAT = Computer Aided Test Menu)
* Use the cursors keys on the remote to select a mode.
* And press the Action key {} to access the menu.
* To exit each mode, press the {R} button.
* To exit the CAT menu, press the {STATUS} button.
* Press {POWER} button on the Plasma to exit the service mode. |
Panasonic Guest
Posted: Sat Jul 21, 2007 2:09 am Post subject: Service Menu Key Sequence |
PLASMAS 3UY / 4UY / 5UY / 6UY / 7UY:
(Status button is the one below Power button)
Disclaimer:
Privacy Policy
Advertise on RiddedTV.com
