Panasonic TC-L32X1 - Turns off
Eliasib
PostPosted: Sun May 15, 2016 7:15 am    Post subject: Panasonic TC-L32X1 - Turns off Reply with quote
Hi guys.. I am a new member of this wonderful forum. I write you because I know you can help to solve a failura that is driving me mad. I have the LCD panasonic TC-32X1 which turns on normally but then after a few seconds it turns off a either image or sound dissappear. The red LED stays blinking without stopping and this blinking does not correspond the number of times the led should blink to indicate where the failure is according to the Panasonic Led blinking chart..I must say that when the TV is not powered for several days and I turn it on then it stays on for over an hour then it turns off.. I have checked out all the power supply and all seems to be ok. What do you recommend me? I am from venezuela but I am in colombia and there is no information about this kind of failure or parts for this TV. Thanks for your response
Eliasib
PostPosted: Mon May 16, 2016 8:28 am    Post subject: Reply with quote
Please I need your help and suggestions. If you have the shcematic for this TV, please post it here. Thank you for your help beforehand
PostPosted: Mon May 16, 2016 1:35 pm    Post subject: Reply with quote
HERE
Eliasib
PostPosted: Fri May 20, 2016 8:21 am    Post subject: Reply with quote
Thank you for your help JTS. God bless you
Eliasib
PostPosted: Sun May 29, 2016 11:09 am    Post subject: Reply with quote
How difficult it is to repair a LCD TV or LEd TV when the parts are not found easily around the place or city where you live; I think this kind of TV offers good quality of iamge and takes up little space but I prefer the CRT TVs because I have still repaired CRT TVs with over 20 years of use.. A country like mine, this kind of TV (LCD or LED) is considered as eletronic trashes. ..
Eliasib
PostPosted: Sun May 29, 2016 11:10 am    Post subject: Reply with quote
PostPosted: Sun May 29, 2016 2:42 pm    Post subject: Reply with quote
Most common way to repair these sets is to troubleshoot set down to the 'board most likely' to cause the failure.
Many companies will supply USED boards. Let the buyer beware. Perform your due diligence BEFORE placing ANY orders.
Most large companies (Shop Jimmy, Ebay and Amazon, for example) will ship Internationally. Columbia is listed for both Amazon & Ebay ... Venezuela isn't on Ebays list for some reason.
