Panasonic tc-p42c2 - 10 blinks   Goto page 1, 2  Next
pipelayer_99
PostPosted: Mon Jul 06, 2015 11:16 pm    Post subject: Panasonic tc-p42c2 - 10 blinks Reply with quote
My neighbor gave this TV to me and it has the 10 blink issue. I searched around and did some diagnosing. I'm not great with electronics but I like to learn and fix what I can. I have 5v on P7 connector and nothing for 15V on P6.
The TV clicks when turned on but no screen. Only the blinking light by the power button.
Does this mean the power board is bad? or could it still be something else?
Any help is appreciated.
PostPosted: Tue Jul 07, 2015 2:13 am    Post subject: Reply with quote
10 Blinks: Abnormalities of the F+15V.
Reasons:
The P board is not generating the F+15V
SUB Voltages are affected by the K board or by metal object present in the SD card slot..
Shorted Vsus (By the SS board or SC board).
Shorted Vda (By the panel, C1, or C2 board).
Wrong diagnostic by the A board.
pipelayer_99
PostPosted: Tue Jul 07, 2015 7:21 am    Post subject: Reply with quote
I removed the plug from P7 to A6 and still don't get 15V on P7. Can I remove all the plugs from the power board to see if the power is there and if it blinks?
I checked the SD slot and nothing foreign in it.
How would I diagnose the other possible issues?
PostPosted: Tue Jul 07, 2015 12:20 pm    Post subject: Reply with quote
With all else connected normally.
Unplug the TV and remove connectors SS11 from the SS board and SN2 from the SN board.
Plug in the TV and press the power switch - Does the number of blinks change to 7 blinks?
pipelayer_99
PostPosted: Tue Jul 07, 2015 3:49 pm    Post subject: Reply with quote
I see the SS11 and the other one is SN2. I'm assuming you want the two wires going from power module to SC and SS disconnected.
I disconnected them both and got 7 blinks.
PostPosted: Tue Jul 07, 2015 3:52 pm    Post subject: Reply with quote
Reconnect SS11. Plug in the TV and press the power switch - Does the TV shut down with 10 blinks?
pipelayer_99
PostPosted: Tue Jul 07, 2015 4:08 pm    Post subject: Reply with quote
SS11 connected and SC2 disconnected.
Back to 10 blinks
PostPosted: Tue Jul 07, 2015 5:15 pm    Post subject: Reply with quote
Sorry. Doing two Panasonic plasmas simultaneously is confusing me. The fact that I work on 10 times more LCD sets than Plasmas isn't helping either.
Tech Manual I found covers multiple models. Service Manual shows 'SN' (SC/SD/SU combined) is correct.
SS board?
Let's try this, with everything connected normally, back-probe SS11 or SN2 (or P11 or P2) with DVM on ohms. What reading do you get?
pipelayer_99
PostPosted: Tue Jul 07, 2015 5:19 pm    Post subject: Reply with quote
http://www.justanswer.com/tv-repair/6e5ck-panasonic-tcp42c2-plasma-10-blink-error.html#re.v/184/
Scroll down where it shows how to remove the rear cover. Beneath that is the internal layout of the TV.
I disconnected the two wires going from power module to SS and SC.
PostPosted: Tue Jul 07, 2015 6:36 pm    Post subject: Reply with quote
PCB #s - I'm aware of layout .
SN = TXNSN1LFUU
SS = TXNSS1LFUU
With everything connected is there a close to zero ohm reading at any point on the VSUS line?
Previous: Let's try this, with everything connected normally, back-probe SS11 or SN2 (or P11 or P2) with DVM on ohms. What reading do you get?
Goto page 1, 2  Next
Page 1 of 2
