Panasonic tc14L10m3 not showing(booting)
Ikpeadan
PostPosted: Sat May 26, 2012 10:32 pm    Post subject: Panasonic tc14L10m3 not showing(booting) Reply with quote
My panasonic tc14L10m3 went off but the power light is on yet not booting . I tested the 'Lopt', still good . And i checked the various supply voltage to the function Ic, oscillator Ic and the EEprom chip all voltages correct. But i discover that B+ to the Lopt is not upto 110v as it supposed, then i replace the power pack section with a nomal supply power packed delivery 110v to the Lopt. Now all votage is ok but the Tv won't boot....oh ! . Pls help .i don't know what to do next !
PostPosted: Mon May 28, 2012 1:04 am    Post subject: Reply with quote
'Lopt' has normal drive waveform on base?
Ikpeadan
PostPosted: Thu May 31, 2012 3:58 pm    Post subject: Panasonic tc14L10m3 Reply with quote
No, there is no waveform in the base of the Hot!...... And i also discoverd that the +16v dc voltage on the primary of a small transformer that takes signal to d base of the Hot, is shorten to earth. But if i should remove the mosfet transistor driving the tranformer, there will be no more short . Then i read d fet and it was good but i replaced it with another one. yet the problem persist +B of d transformer shorten to earth......
PostPosted: Thu May 31, 2012 7:17 pm    Post subject: Reply with quote
What is chassis number? Also horizontal (lopt) driver and output type numbers?
Ikpeadan
PostPosted: Tue Jun 12, 2012 10:48 pm    Post subject: Panasonic tc14L10m Reply with quote
Sir i'm verry sorry for the delay in reply. This is the chasis & the 'Hot' number TNP4G073 , D2499 .Thanks
PostPosted: Wed Jun 13, 2012 2:57 am    Post subject: Reply with quote
Chassis number may be more like perhaps MX-5Z?
Are you sure H. DRIVER is a MOSFET?
Ikpeadan
PostPosted: Wed Oct 31, 2012 8:43 pm    Post subject: Reply with quote
Yes it is a mosfet trasistor
