Panasonic TH-42PX25 inputs not working
OldGuy
PostPosted: Tue Aug 28, 2012 9:06 pm    Post subject: Panasonic TH-42PX25 inputs not working Reply with quote
The TV has 2 component inputs, one HDMI, 3 composite inputs, 2 antenna inputs, and a PC 15 pin VGA input. I can connect a PC to the VGA input and use the TV as a computer monitor with no problem. I have tried the HDMI, both component inputs, and all three composite inputs with no luck. I have used a set top box and a dvd player to test the different inputs. Both of those devices work with other TVs. I can get the OSD to work with no problems. When I run the self test, everything checks out. When I connect the TV directly to my cable without going through the cable box, it finds several digital channels with audio and three with video.
I've used JustAnswer twice with this TV. In one case, the "expert" gave up on the problem and turned me over to another "expert." In both cases, the JustAnswer expert assured me that the problem was the H board. This seems reasonable, as all of the inputs except the VGA input go through that board. The board is relatively inexpensive, so I have purchased two of them. The TV responds identically with either my original board or either of the ones I purchased.
Does anyone have any experience with this set?
