Panasonic thD10 Japan made accidentally plugged to 220 volts
mlagui27
PostPosted: Fri May 01, 2009 8:25 am    Post subject: Panasonic thD10 Japan made accidentally plugged to 220 volts Reply with quote
This Japan made model runs at 110 volts but my father forgot it and accidentally plugged in 220 volts, then it stopped running... can this still be repaired?
PostPosted: Fri May 01, 2009 10:40 am    Post subject: Reply with quote
if you're lucky, it probably just killed the power supply portion.
