Part #: 483531057582 Vertical hold repair kit
Tagdot
PostPosted: Thu May 22, 2014 5:54 pm    Post subject: Part #: 483531057582 Vertical hold repair kit Reply with quote
I am looking for Philips Part #: 483531057582 Vertical hold repair kit I cant find this part. Does any one know what parts are in the kit and if those are available to order separate?
PostPosted: Thu May 22, 2014 8:16 pm    Post subject: Reply with quote
KIT PART NUMBER
4835 310 57582
Item Description Part Number
2244 100n 63v 2222 370 76104
2252 1n 25v SMD under 3244 3198 016 31020
2253 1n 25v SMD under 3249 3198 016 31020
2474 2n2 50v SMD to pin 1 of IC7471 4835 122 87083
3474 2K2 3/5 watt 2312 915 12202
3479 2K7 SMD to pin 9 of IC7471 4822 117 12955
3488 4R7 fuse 4835 110 47023
6487 FS diode 4835 130 37094
6470 FS diode SMD 4835 130 37583
7471 TDA8359J Output IC 9352 701 64112
Installation Note 1715990611
Tagdot
PostPosted: Mon May 26, 2014 4:05 pm    Post subject: Reply with quote
Thank you, I will look up those part numbers
