Philips 23PF5320/28 No Power
goingHD
PostPosted: Sat Aug 07, 2010 1:42 pm    Post subject: Philips 23PF5320/28 No Power Reply with quote
I have a Philips 23PF5320/28, and it appears that it is not getting power to the unit. The cord is good and so is the fuse on the power supply board.
I pulled out the power supply board and it has a burn mark near a resistor (marked 3081, and a diode (marked 6068). The burn mark is between those 2 componants. Is there a way I can tell what the values of the resistor and diode are based on the componant numbers printed on the board? If I replace those 2 componants do you think it will fix it? or is there some other underlying problem?
Thanks In Advance
John
PostPosted: Sat Aug 07, 2010 4:49 pm    Post subject: Reply with quote
Compare location numbers to same numbers in the parts list and on the schematic in this service literature. Cool
http://elektrotanya.com/philips_mod-23pf5320-28_chasis_ml1.2_sm.zip/download.html
3081 212010500027 RST MOX 1W RSS A 0R15 PM1 A (.15 ohm 1 watt)
6068 ? Can't find listed other than as part of other part numbers.
Also check: Dead - No LED light
6062 Diode NTE 552
7062 Regulator P10NK80ZFP
goingHD
PostPosted: Sat Aug 07, 2010 5:48 pm    Post subject: Reply with quote
Thanks for the reply.
I removed the resistor and it is definately burned.
Do you think that something else may have caused that resistor to blow?
I looked on the schematic and there is a FET upstream of that,
(part # 7062 - STP10NK80Z)
should I replace that as well?
Thanks
Johhn
PostPosted: Sun Aug 08, 2010 12:08 am    Post subject: Reply with quote
Check it for shorts. Diodes as well.
