Philips 25pt5324 service menu
patator
PostPosted: Sat Aug 30, 2014 8:18 am    Post subject: Philips 25pt5324 service menu Reply with quote
hello there,
My name is Johan and I am french, this post because I need help, I have a philips tv 25pt5324 which works very well but I need to adjust geometry.
Only here is the same on the way codes like 062,596 + i / menu etc ... it does not work.
I have 2 philips remotes it takes a special ?? something to do with special ??
thank you for your help
PostPosted: Sat Aug 30, 2014 9:54 am    Post subject: Reply with quote
1) Geometry was satisfactory when TV was first unboxed around year 1998?
2) Service Geometry modes/parameters/values were MISALIGNED to cause the current condition?
IF your answer to question #1 is YES and your answer to question #2 is NO, than more likely one or more components (most likely electrolytic capacitors) have drifted from their original specification to cause current condition.
I highly urge you to record (as in write down) which parameters/values you changed from what, to what, so that IF adjustments of Geometry do not solve the current condition and later a defective part is found and replaced, Geometry can then be returned to their original settings!
http://elektrotanya.com/philips_a8.0e_aa_chassis_tv_sm_only.pdf/download.html
patator
PostPosted: Sat Aug 30, 2014 11:25 am    Post subject: Reply with quote
The tv works well, no death component, I renovated arcade games but according to the game I need to review the geometry.
But I can not return to a menu.
PostPosted: Sat Aug 30, 2014 12:29 pm    Post subject: Reply with quote
First, you may want to resize that picture.
Second, this is the first mention that the Philips product is being used for other than consumer purpose.
Now, if I understand correctly, a) the game is telling you the game's geometry is off or b) the game is telling you the monitor's geometry is off?
patator
PostPosted: Sat Aug 30, 2014 1:09 pm    Post subject: Reply with quote
yes i want to resize That picture.
And yes I have to adjust the geometry of the screen by the game, a screen arcade has adjustment knobs, and an adjustment for a game (even if I want to do an overall adjustment in the vertical), but having put a tv I do not have access.
Hence my request for help to be able to adjust the geometry.
PostPosted: Sat Aug 30, 2014 5:58 pm    Post subject: Reply with quote
Previous link will take you to tv alignment procedures. My warnings still apply.
You may have to set it free from the game. Depends how game makers designed interfaces. TV may not have its original keypad, remote receiver, tuner, etc.
patator
PostPosted: Sun Aug 31, 2014 3:21 am    Post subject: Reply with quote
Ok I understand, but there's there other codes to go with Remote ???
PostPosted: Sun Aug 31, 2014 8:48 am    Post subject: Reply with quote
You haven't said which ones. I am NOT psychic.
From page 9 & 10:
A8 sets can be put in the two service modes via the RC7150.
These are the Service Default Mode (SDM) and the Service
Alignment Mode (SAM). SDM can also be entered by short
circuiting the jumpers 9040 and 9041 on the chassis with a
screwdriver.
Entering the SDM:
– By transmitting the "DEFAULT" command with the RC7150
Dealer Service Tool (this works both while the set is in
normal operation mode or in the SAM)
– By shorting jumpers 9040 and 9041 on the monocarrier
with a screwdriver while switching on the set
By temporarily shorting jumper 9040 and 9041 when switching
the set on, the 5V protection is disabled.
CAUTION ! Overriding the 5V protection should only be used
for a short period of time.
Service Alignment Mode (SAM)
The purpose of the SAM is to do alignments, option settings,
display/clear the error code buffer and reload default values.
Entering SAM:
– By transmitting the "ALIGN" command with the RC7150
normal operation mode or in the SDM)
– By pressing the "VOLUME +" and "VOLUME -" key on the
local keyboard simultaneously when the set is in SDM
